Spotify Not Downloading Songs? 9 Fixes for iPhone, Android, and PC
Summary: Spotify downloads can stall because of Premium eligibility, device limits, storage, network permissions, cache state, or a service incident. This guide gives one nine-fix recovery path, then separates iPhone, Android, Windows/Mac, Apple Watch, partial-playlist, Offline Mode, and clean-reinstall cases. It also explains when a MusicFab local-file workflow fits authorized personal use.
When Spotify is not downloading, start with Premium status, device limits, free storage, network permissions, and service status. A Spotify download issue that survives those checks usually belongs to a device branch or damaged cache. The route below moves from quick account checks to device-specific fixes, offline playback, and a local-file alternative.
I treat a frozen queue as an eligibility or cache problem first; jumping straight to a new tool can hide a simple account or network fix.
Spotify Not Downloading? Check These First
The fastest route through a Spotify download issue is one consistent nine-fix pass. It checks the account gate, local resources, connection, app state, and Offline Mode in an order that limits unnecessary resets.
- Confirm Premium eligibility. Music downloads require Premium; free accounts can download podcasts, not music.
- Check device and track limits. Stay within five offline devices and 10,000 tracks per device, and bring the account online at least once every 30 days.
- Free local storage. Check available space before retrying a large playlist.
- Change the connection. Try stable Wi-Fi, allow cellular downloads when appropriate, and pause VPN or proxy filtering for the test.
- Use automatic date and time. Clock drift can interrupt account authorization and offline checks.
- Clear the Spotify cache. Force-quit and reopen the app, then retry before deleting app data.
- Check Spotify service status. A platform incident calls for a later retry, not repeated device resets.
- Retry one small item. A track or short playlist separates a queue problem from a wider account or network failure.
- Verify Offline Mode. Turn it on, test in airplane mode, and reconnect periodically so the account can refresh.
For a Spotify stuck downloading queue, I start with Premium, storage, and service status before touching a reinstall. Those checks are quick and preserve existing offline downloads.
Confirm Premium, limits, and storage
Spotify download limits are account rules, not signs that a phone is broken. Music requires Premium, offline use is limited to five devices with up to 10,000 tracks on each device, and the account must connect online at least once every 30 days.
Check the storage screen and remove unused downloads before rebuilding a queue. If the save location is unclear, the explanation of where Spotify saves music identifies the location worth inspecting.
Check network, cache, and service status
A frozen queue often clears after a connection change, cache reset, or confirmed service recovery. Allow Spotify through a desktop firewall, pause a filtering VPN or proxy, and check cellular-download permission on mobile.
Set the date and time automatically, force-quit Spotify, reopen it, and clear its cache. Keep app data deletion for the reinstall path because it removes existing offline downloads.
Match the Fix to Your Device
The right fix changes by device: Spotify download iPhone, Spotify download Android, and Spotify download PC failures can have different background, storage, battery, or firewall causes. Use the symptom row first, then apply the platform-specific action.
| Symptom | iPhone/iPad | Android | Windows/Mac | Apple Watch |
| Waiting or frozen | Background Refresh; Wi-Fi retry | Battery unrestricted; clear cache | Firewall/VPN/proxy; update | Retry one item; re-pair |
| Stops in background | Low Power off; cellular allowed | Background data; saver off | Sleep settings; stable network | Keep watch near phone |
| Partial playlist | Storage; re-add track | Storage location | Disk space; retry queue | One item at a time |
| Fails offline | Offline Mode; airplane test | Offline Mode; airplane test | Offline Mode; airplane test | Reconnect through phone |
| Reinstall trigger | Cache reset keeps failing | Residual data conflict | Residual files conflict | Re-pair or reinstall |
iPhone and iPad
Spotify announced background downloads for music and podcasts on iOS on May 28, 2026, but rollout, Background App Refresh, Low Power Mode, cellular settings, and account behavior still affect results. Spotify does not universally need to remain open.
Start a short playlist, minimize Spotify, and watch whether the queue advances. If it stops, enable Background App Refresh, turn off Low Power Mode, permit cellular downloads when needed, and retry after signing in again.
Android
On Android, battery optimization and background activity are the common split points. Allow Spotify to run in the background, check the selected storage location, clear its cache, and permit mobile data when Wi-Fi is unavailable.
Set Spotify's battery use to unrestricted, start one playlist, and lock the screen. A queue that continues points to a resolved background restriction; a queue that still waits calls for storage, cache, or account checks.
Windows and Mac
Spotify downloads on desktop depend on disk space, the client, and the network path. Check Windows Defender Firewall or the macOS firewall, pause VPN or proxy filtering, install the current client update, and retry a small playlist.
Allow Spotify through the firewall, start one playlist, and let the display sleep. If the queue stops after sleep, adjust the network or sleep setting; if it stops immediately, return to account and cache checks.
Apple Watch and podcasts
Apple Watch queues can wait when the watch is not near the paired phone, storage is tight, or several items are queued together. Re-pair or reinstall Spotify when a one-item retry fails, then send one podcast episode or playlist segment at a time.
When a Playlist Is Only Partly Downloaded
A Spotify playlist not fully downloaded needs two checks: whether each track is available to the account, and whether the downloaded state survives an Offline Mode test. A green icon alone does not prove offline playback.
Greyed-out or unavailable tracks
Greyed-out titles can be unavailable in the current region, replaced by another version, filtered by explicit-content settings, or blocked by the local track limit. Choose an available version, add it back to the playlist, and download again.
When one title loops on “Waiting,” remove and re-add that track before changing the whole playlist. Compare it with the steps in the Spotify music download guide, then retry the available version.
Downloaded but unavailable offline
Spotify offline playback should be verified with Offline Mode and an airplane-mode test. If the track plays only while connected, turn Offline Mode off and on, retry the download, and reconnect the account online at least once every 30 days.
This test separates a cached queue from a playable offline state. It can also expose a playlist whose visible download marker remained after a track was replaced or removed.
Clean Reinstall and Re-download
A clean reinstall is the last resort after account, storage, network, cache, and service checks. Existing offline downloads are removed, so plan to download playlists again after signing in.
- Sign out. Close Spotify and sign out on the affected device.
- Uninstall the app. Remove Spotify, then delete documented residual app data where the platform instructions call for it.
- Install a fresh client. Reinstall Spotify from the platform's normal app channel and sign in.
- Rebuild downloads. Start with one short playlist, confirm Offline Mode, and then add larger queues.
When In-App Downloads Still Fail
When you need to download Spotify songs to files, separate Spotify's in-app cache from a local-file workflow. Official downloads are managed inside Spotify and checked through the account; regular audio files are organized outside that cache.
In-app downloads versus local audio files
Spotify's native Offline Mode fits readers who only need playback inside the app. A local-file workflow makes more sense when Windows or Mac organization, cross-device file management, or a personal backup routine matters.
MusicFab Spotify Converter: fit and limits
For personal offline use of content you're authorized to access with an active Spotify subscription, where permitted by platform terms and applicable law, MusicFab Spotify Converter offers a Windows/Mac local-file workflow when Spotify's in-app path does not fit. It uses direct source download technology, a different path from Spotify's app cache.
- Best for: Windows and Mac users who need organized local files, batch queues, and editable metadata.
- Not ideal for: readers satisfied with Spotify's native Offline Mode.
- Batch download Spotify tracks, albums, playlists, podcasts and video podcasts
- Convert songs to MP3, FLAC, WAV, M4A and other formats
- Retain original audio quality up to lossless & metadata
- Download with Spotify Free or Premium account
The MusicFab Spotify Converter includes a 30-day trial with three full songs per service, so the workflow can be checked on complete tracks before a license decision.
How to use MusicFab to download Spotify tracks?
MusicFab output specifications
| Capability | MusicFab Spotify Converter |
| Formats | MP3, M4A (AAC), WAV, FLAC, OPUS |
| Quality | Up to 320 kbps; 24-bit / 44.1 kHz |
| Batch queues | Albums, playlists, podcasts, audiobooks |
| Metadata | ID3 fields, cover art, track numbers |
| Lyrics | Embedded lyrics or .lrc files |
The trade-off is clear: the Spotify app keeps native controls, while MusicFab adds file-level organization and format choice on a desktop. Choose the path that matches where you listen.
Frequently Asked Questions
Q1. Could a Spotify outage be causing downloads to fail for everyone?
Yes. Check Spotify's service status before changing device settings. If the incident is widespread, wait for recovery; if only one device fails, continue with its permission, storage, and cache checks.
Q2. Will clearing the Spotify cache delete my offline downloads?
Clearing cache is less disruptive than deleting app data or reinstalling, but platform behavior can differ. Avoid app-data deletion unless you are ready to download offline content again.
Q3. Should I reinstall Spotify if only one playlist is stuck?
Not first. Retry one track, remove and re-add the affected title, test a short playlist, and check service status. Reinstall only when multiple queues fail after account and cache checks.
Q4. When is a local-file workflow more useful than Spotify Offline Mode?
Choose Offline Mode for listening inside Spotify. A local-file workflow better fits authorized personal use when you need desktop file organization, format choice, or playback through software outside Spotify.
Conclusion: A Practical Recovery Order
To fix Spotify not downloading, start with Premium eligibility and the five-device or 10,000-track limits, then check storage, network permissions, date and time, cache, and service status. Match the next action to iPhone, Android, Windows/Mac, or Apple Watch, verify Offline Mode in airplane mode, and reserve a clean reinstall for persistent failures.
My cutoff is practical: after the account, permission, Offline Mode, and one clean-reinstall checks, repeating the same reset rarely adds information. If the real need is organized local audio files rather than Spotify's cache, the authorized desktop path above is the more direct decision.
