TunePat Spotify Converter Review (2026 Test): Is It Worth It?
TunePat lets you convert Spotify tracks into versatile formats like MP3, FLAC, WAV, AAC, and AIFF. We tested its features, speed, and stability, then compared it with MusicFab. Is TunePat safe? Does it actually work well? This article shows you the latest test results of TunePat Spotify Converter review.
Before diving into the review, here's some basic info:
TunePat offers multiple products; for this test, I used TunePat Music One (which supports all platforms). The functionality, performance, and results tested are identical to those of the single TunePat Spotify Converter.
- Test environment: Windows 64-bit laptop (Ryzen 7 5800U, 16GB RAM)
- Tested version: TunePat Music One, v 2.5.0.
- Update note: TunePat continues to release updates. To check your version in the menu, check for Updates for the latest build.
To download the latest version directly, go to TunePat download center.
website: https://www.tunepat.com/download-center.
1. TunePat Spotify Converter Features
TunePat Spotify Converter, as its name suggests, enables you to convert and download your favorite Spotify tracks. It records music to convert Spotify tracks to common file formats like MP3, so you can transfer the audio to any device you want.
Key Features of TunePat Spotify Converter:
| Output Formats | MP3, AAC, WAV, FLAC, ALAC, and AIFF. |
| Batch Conversion | download entire playlists, albums, or podcasts all at once |
| ID3 Tag Retention | Artist, album, song title, and album artwork |
| Support Audio Types | Songs/albums/playlists/podcasts/audiobooks/music videos |
2. How to Use TunePat Spotify Converter?
How to use TunePat to convert and download Spotify songs?
I use the free trial version of TunePat. It allows you to explore all the features of the paid version, but you can only download the first minute of each song. This is not very friendly.
Here are the steps:
- Launch the tool and choose the Spotify app
- Login to your account and select a song or playlist to download. Click the add button, then it will analyze the playlists > Convert to begin the download. You can see the process of downloading.
As you can see, downloading this 4-minute song from the playlist takes about 10 to 15 seconds. (In fact, it only downloaded the first minute of the song.)
I don't think this speed lives up to the advertised claims. For users who need to download thousands of songs, this difference is significant.
- Once it finished, you can go to History, click the file icon, and see the metadata info.
The song I download is 256 kbps:
How to change and set the mode and format on TunePat?
- Click the Settings button in the lower-left corner to pick your desired mode and format.
- If you choose the record mode, you can even select the record speed of 1X, 5X, or 10X.
How to choose the audio bitrate and other quality settings on TunePat?
You can change bitrate and quality settings in the TunePat, but the menu can look different depending on the source(App vs Web Player).
Go to Settings > Music to adjust output format, bit rate, sample rate, and output folder. If you don't see bitrate options, switch the conversion source and check again.
3. My Experiences of Using TunePat
I use the same system and device when comparing music converters. Compared to the TuneFab Spotify Music Converter I reviewed, Tunepat features a cleaner interface, smoother workflow, and is easier to get started with.
Speed was okay for a single track but felt less efficient for large batches, especially when using record-based modes. Since the free trial only converts the first minute of each song, I can't verify the full-length quality or how it handles hour-long podcasts or mixes.
How fast is TunePat Spotify Converter in real use?
FYI, using the intelligent mode, downloading a playlist with a total duration of three and a half hours and containing 56 songs is estimated to take 21 minutes.
4. TunePat User Reviews & Feedback
On Trustpilot, TunePat receives a score of 4.4/5 so far.
These are the most frequently occurring words in users' 5-star and 4-star positive reviews; You can see that users praised it for its quality and ease of use, especially for Spotify music conversion.
these are words users mentioned most in 1-star and 2-star reviews. They complained about Tunepat's customer service, trial limits, refund policy, and some occasional bugs or errors.
5. TunePat Spotify Converter Pricing
TunePat free trial only allows you to convert the first minute of each song.
To unlock the full-length music, TunePat offers three different options for premium users:
- 3-month plan – Plan charges are $ 29.95. Five-day money-back guarantee
- Annual plan – Plan charges are $ 44.95. Five-day money-back guarantee
- Lifetime plan – Plan charges are $ 89.90. It comes with 30 30-day money-back guarantee.
6. Is TunePat Safe? Your Top Concern Answered
Generally safe to install and use, but you should understand how login, privacy, and update risks work, especially after Spotify changes its DRM or app flow.
And remember, it is for personal use only.
7. TunePat vs MusicFab: Meet TunePat Best Alternative
TunePat is fine for light use and smaller batches. If you want steadier speed after Spotify updates, a friendlier trial, consistent high performance, a superior audio quality choice, and broader modern formats, MusicFab Spotify Converter is the better long-term pick.
The biggest difference between MusicFab and Tunepat is that MusicFab saves music locally through downloads, which makes it faster and safer than Tunepat using records.
MusicFab is designed to give you a smooth, secure, and genuinely high-quality experience when converting your Spotify music.
The top features offered by MusicFab Converter include
- Faster downloads: In many cases, MusicFab finishes large batches noticeably faster than record-based tools(actual speed depends on your network and Spotify changes).
- Stability: Frequent updates and better batch stability.
- Multiple file formats: Convert your tracks to several formats. The tool supports MP3, M4A, AAC, and FLAC, among others, to preserve tags/art across big batches more consistently, which is useful if you maintain a long-term, cross-device library.
- High-quality downloads: Enjoy studio-quality performance with resolutions up to 320 kbps & 24 bit.
- Better free trial: MusicFab lets you convert the first three full tracks under a free trial.
For a comprehensive MusicFab review and to see how to use MusicFab to download Spotify songs: 2025 MusicFab Review: Features,FeedBack, User Guide
8. Overview: TunePat vs MusicFab
The table below provides a direct comparison between TunePat Spotify Converter and MusicFab Spotify Converter.
| Feature | TunePat Spotify Converter | MusicFab Spotify Converter |
| Output Formats | MP3, AAC, WAV, FLAC, AIFF | MP3, FLAC, WAV, AAC, M4A, OPUS |
| Conversion Speed | Claims up to 10X; real-world performance can vary. | Consistently up to 20X faster; highly stable on big batches |
| Audio Quality | Generally good for MP3; variability for lossless. | Lossless audio quality guaranteed, up to 320 kbps |
| ID3 Tags | Yes | Yes |
| Ad Removal | Yes | Yes |
| Free Trial | Only first 1 minute of each song | More generous trial, e.g., full track conversions for the first three songs |
| Stability | May experience temporary compatibility issues after Spotify updates. | Unmatched stability. Frequent, proactive updates. |
| Safety | Generally safe from the official site; You need to exercise caution | 100% safe and clean; tested for safety |
